Peters Web Site
Date:  3-11-2017
Number of Hours:  1.00
Manual Reference:  9225501-LOG-03.056
Brief Description:  2: Rolling the Rudder Leading Edge
With the rudder trailing edge done, I could now turn my attention to the leading edge. Here the two skin sections that protrude past the main spar need to be rolled so that you end up with a nice curved surface.
I'd already bought myself a wooden broomstick for the task, so taped this to the right side skin. I then attached a pair of vice grips, and set about forming a nice neat rolled surface.
The left side skin presented a small complication in that the edge of the skin is folded at right angles. To counter this, I used my table saw to create a slot in the broomstick that the skin flange could sit in. Then it was a simple matter of taping the broomstick in place, and forming the rolled edge as per the other side.
I taped a wooden broomstick to the leading edge skin...
... and then with a pair of vise grips, rolled the thin aluminium into a nice curve.
I cut a slot in the broomstick so the left skin flange didn't get damaged while rolling
