Peters Web Site
Date: 2-19-2017
Number of Hours: 2.00
Manual Reference: 9225501-LOG-03.046
Brief Description: 1: Back Riveting the Rudder Stiffeners
Wow, back-riveting is awesome!
This morning I back-riveted all the rudder stiffeners onto the two skins, and am very pleased with how neat every single rivet turned out. Working on one stiffener at a time, I used rivet tape to hold the complete row of rivets in place. I then flipped the skin over and positioned the stiffener over top of the protruding rivet shanks. With a back-rivet set in the rivet gun, and a heavy steel bar underneath, it's then a simple matter of working your way along the row of rivets, setting them as you go. Very easy, and extremely good results. I wish I could set all the rivets this way.
Reading through another builder's log I also found the idea of starting with the longest stiffener first. That way you can re-use the one length of rivet tape for multiple stiffeners, until it loses tackiness. Rivet tape isn't that expensive, but hey, no point throwing it away.
Time for a coffee break while I admire my work.
Rivet tape holds the row of countersunk rivets in place
Back riveting produces very clean rivets
The left rudder skin with it's eight stiffeners neatly riveted in place
