Peters Web Site
Date: 1-29-2017
Number of Hours: 2.50
Manual Reference: 9225501-LOG-03.034
Brief Description: 2: Spray Painting
After alodining was complete I then set up a spray table at the front of the shed, mixed up about a quarter litre of epoxy two-pack primer, and set about spraying all the spar and rib pieces.
I've read some nasty things about two-pack paints so I made sure I was "kitted up" with disposable overalls, gloves, goggles and respirator. Forgot to get a picture, but I'm sure I looked sexy :-).
While I waited for the first side of all the pieces to dry enough to flip over and do the other side, I also dimpled the vertical stabiliser skin on the c-frame dimpler. I then rubbed the inside surface down with isopropyl alcohol and spray painted with acid etch primer.
I finished off the day by priming the back-side of all the rib and spar pieces. Everything is now ready for riveting together, however I'm in Adelaide all next week, so it's going to have to wait until I get back. Oh well, at least that'll give ample time for the paint to properly harden.
Did all my spray painting in the shade at the front of the shed.
All parts primed, and ready for riveting.
