Brief Description: 2: Starting the Vertical Stabiliser
Tonight I also got a start on the vertical stabiliser. This looks like it'll be somewhat simpler than the horizorizontal stabiliser as there's quite a few less parts.
Following the instructions (which are now becoming much less detailed) I first cleco'd the rear spar doubler to the rear spar. I then cleco'd on the three pairs of hinge brackets and match drilled the upper bracket only of the bottom pair.
The next step is preparing the four ribs (deburring, fluting, straightening), so I'll leave it at that for tonight and get a fresh start tomorrow.
