Brief Description: 1: Front Spar Attachment Angles
This morning I finished making the front spar attach angles (HS-908-L/R) and then cleco'd them in place. Had to go for a trip over to the hardware store to get a short length of angle iron so that I could clamp it to both bottom flanges ensuring proper alignment.
Once clamped/cleco'd in place I match drilled all mounting holes to #30.
Next I went on with clecoing the rear spar doubler (HS-906) and eight outboard hinge brackets (HS-912) to the two rear spars (HS-903), and then match drilled all holes to #30.
Finished front spar attachment angles
Attachment angles clamped/cleco'd in place
Front and rear spars both cleco'd and match drilled
