Peters Web Site
Date:  1-19-2020
Number of Hours:  1.50
Manual Reference:  9225501-LOG-06.018
Brief Description:  3: Ammeter Shunt and Alternator Fuse
Another short burst at the goddam f*#@ing gear leg weldment, then onto yet another firewall doubler plate, this time for the ammeter shunt and alternator fuse block.
I'm installing my ammeter shunt in series with the alternator, so it needs to have a direct connection to the alternator fuse block. The first picture below shows the copper link I made up to connect the two as simply as possible.
Since these two items also need to be mounted to the firewall, then yet another doubler plate is called for. I started making one up, but then ran out of time.
I'll match drill and rivet it to the firewall another day.
The ammeter shunt (top) and alternator fuse block (bottom) connected with a copper link
Making up a doubler plate for the firewall
