I spent the Easter break working at the Roxby Downs Aeroplane Company, and managed to get quite a bit of wiring completed. I made it my goal to get the two EFIS 37-pin wiring harnesses finished, plus I also ran in the wiring harnesses for the Engine Management System sensors.
Wiring is now done for the following: * Elevator trim system * VHF Comm Radio * Intercom * Transponder * Flap position system * Angle of Attack system * Instrument panale switches (except ignition) * Panel light dimmer * CO monitor * Level button * Audio mixer * Skyview network
Still need to complete wiring for the following: * Landing and taxi lights * Nav/strobe lights * Wing inspection lights (might decide to drop these) * Cockpit and baggage area lights * Voltage regulator (having trouble finding somewhere to mount it) * Pilot/copilot headset sockets * Ignition switch * Engine sensors * Main power cables * Backup Primary Flight Display * Autopilot
I'm getting there.
Supporting the EFIS 37-pin connector while making off the wiring loom
Both EFIS 37-pin connectors are done
There is getting to be an awful lot of wires back there
