Peters Web Site
Date:  11-4-2018
Number of Hours:  4.00
Manual Reference:  9225501-LOG-11.009
Brief Description:  1: Mounting Avionics
I continued today with mounting of avionics on the instrument sub-panel. I initially thought that everything was going to fit, but after considering where cable penetrations would need to go, and allowing space to get connectors on and off, then I found that I will need to mount my AoA equipment elsewhere.
I already had the VP-X and VHF COM fitted yesterday. Today I installed the Network Hub, the EFIS battery back-up, the stall warning printed circuit board, and the Dynon EMS. Of course, everything is mounted using nutplates. I'd hate to have to get anything out if it had nuts on the back.
The instrument sub-panel is now full of avionics
Skyview network hub, battery back-up, and stall warning PC board
Dynon EMS, with plenty of room above for cable penetrations
