Not sure why, but I didn't seem to take many pictures today. I continued on with installation of the fuel pump. I found a few of the nutplates I needed to finish off the mounting brackets. With the pump securely fixed in place I could then also make up the tubing that runs from the pump to the firewall.
Unfortunately the plans are not very clear on where the fuel line needs to go through the firewall so I simply left what I hope is more than enough length on the tubing to make up the final bends later.
Fuel pump installed, and the fuel line to the engine made up
