Another day affected by this horrible cold, so another day of not much work. I managed two hours in the morning and an hour-and-a-half in the afternoon before I had to give it away.
I did manage to get the autopilot pitch servo almost done, so that was good. After a test fit-up I riveted the servo mounting bracket into place. I then took the elevator bellcrank out so that I could drill a hole for the servo linkage.
I also soldered a DIN plug to the end of the servo wires. The Dynon instructions suggest a male plug is required, however I want to plug this servo direct into a network hub which I'm going to mount close by, so I fitted it off with a female instead.
Test fitting the servo and mounting bracket
I added a female plug to the servo lead so I can plug it straight into a Skyview Network Hub
