I spent time this evening inspecting and relabeling some of my instrument wiring harnesses. Some of these may need to some slight modification when installing behind the instrument panel. They came out of another RV-8 so there may be some ground and/or power leads that require lengthening to reach my fuse blocks and ground posts. I expect most of them to work fine as is. I will have to inspect the molex connectors on the instruments as well. I already noticed one wire/connector continuity problem that will require correction. Anyway, I hope to get these installed in the next couple days.
