I went to a local industrial surplus outlet this morning and scrounged a selection of small Molex wiring connectors made for small wire gauges. Using the Molex connectors and appropriate gauge wire I fabricated harnesses for attaching the roll servo and the pitch/roll LED indicators that will be part of the trim circuitry.
I still need a few Molex connectors to complete the trim relay wiring but they should be available in the next day or two. When they arrive I will be able to complete the installation of the pitch/roll trim relays which include speed control. Based on the schematics, I think it will be necessary to run three more small gauge wires to the stick terminal strip under the forward cockpit floor. Seems like everytime I think the last wire has been run, another requirement appears.
