Installing the propeller governor took longer than expected. I began by installing the cable mounting bracket on the governor per the directions and quickly found that the recommended orientation was not going to work. It took a few tries but eventually I got the angle of the bracket to line up with the control cable and the actuator arm at an angle allowing its proper operation from stop to stop (I hope).
