Brief Description: Final painting of forward fuselage & clean-up
I did some final painting and touch up of panels in the forward fuselage. Afterwards, the masking paper and tape were removed and the residual glue from the tape was removed using Goo-Off. The forward part of the fuselage isn't perfect but it looks pretty good and the metal should be protected somewhat against corrosion and general wear and tear.
