Rather than finding another jug or tub to hold my wingnut clecos, I decided to fabricate a simple organizer out of some scrap wood. The block shown was made from a piece of 1x4 pine. I just layed out a grid on each end of the block and drilled with appropriate bits to hold the 3/32" and 1/8" clecos. In the middle I drilled a hole slightly larger than 1/4" to hold the wingnut driver. The driver is a socket that can be inserted in an electric screwdriver and will fit either wingnut or hexnut draw type clecos.
