Brief Description: Riveted the vertical stabilizer rear spar
Clecoed the vertical stabilizer reinforcement plate to the spar channel (VS-803PP to VS-808PP). Clecoed the hinge brackets (VS-410PP, VS-411PP and VS-412PP) to the spar assembly. Taped over holes that will attach the VS-704, VS-706 and VS-707 ribs.
Riveted the vertical stabilizer rear spar together remembering the flush rivets on the lower end of the spar channel.
