Pete's RV-8 Web Site
Date:  9-12-2014
Number of Hours:  10.00
Brief Description:  Began work on prop spinner
Today was a long day fabricating the spinner bulkhead and backing plate with doubler. The 13" backing plate had to be cut to match the doubler. This was primarily a fly cutter operation (very carefully accomplished on a drill press).
Once the main plate was cut it was match drilled, deburred, prepared and primed. Finally, the backing plate was riveted to the doubler.
Plates Ready
Plates Ready
Trimming Spinner
Trimming Spinner
Fitting Spinner
Fitting Spinner
