Pete's RV-8 Web Site
Date:  7-1-2008
Brief Description:  Back riveting plate
I mounted the back riveting plate purchased from Cleaveland Tool on the surface of a piece of particle board. Around all four edges of the plate I attached some thin (about 1/4") project plywood purchased in a 2'x2' sheet at Lowe's. The same out door carpet used on the DRDT-2 work surface was then glued on the plywood to protect the aluminum parts as they are riveted.
Back Rivet Plate Mounted
