On the underside of the skirt I removed the clay material, applied filler, and then sanded. This was a multi-step process until I got the finished look I wanted. Particular attention was required around the canopy rail slot.
I also cut a couple canopy stops from rubber fuel line and inserted in the canopy side rails to keep the canopy from banging back against ther rear seat bulkhead.
