Pete's RV-8 Web Site
Date:  2-27-2016
Brief Description:  Cowl inlet strips (to anchor rubber seals)
I formed these strips out of the wrong aluminum stock, 1" rather than 1/2". That made the process harder. Anyway, the strips were hand formed a little bit at a time to fit the contour of the fiberglass cowl inlets. Later, these strips will be used to fasten the rubber material in place to seal the inlet ramps.
Starboard Strip (?)
Starboard Strip (?)
Port Side Strip (?)
Port Side Strip (?)
