Pete's RV-8 Web Site
Date:  10-21-2013
Number of Hours:  3.00
Brief Description:  Install prop governor
Installing the propeller governor took longer than expected. I began by installing the cable mounting bracket on the governor per the directions and quickly found that the recommended orientation was not going to work. It took a few tries but eventually I got the angle of the bracket to line up with the control cable and the actuator arm at an angle allowing its proper operation from stop to stop (I hope).
SIde View
SIde View
Rod End Bearing
Rod End Bearing
Cable Bracket & Angle
