Brief Description: Terminating wires on strip under front cockpit
Continued working today on wire terminations concentrating on the area under the pilot. All the circuits were terminated on the terminal strips. The two Infinity sticks were temporarily connected to the strips and the trim servo circuits were tested. This included the trim governors (pitch and roll), the Ray Allen servos, and the applicable wiring. It seems to work as advertised. I may have to switch a couple wires in the final installation to be sure the servos work in the proper direction (pitch up vs down and roll right vs left). I will also have to adjust trim speed once we are ready to fly. I believe the current servo speed is a little slow.
