Pete's RV-8 Web Site
Date:  4-6-2012
Number of Hours:  0.00
Brief Description:  Ameri-King 406/121.5 ELT
Ordered and received an Ameri-King 406/121.5 ELT from Aircraft Spruce. This unit will be intsalled in the tailcone of the aircraft but can also be operated as a portable using a second supplied antenna not requiring a ground plane. Kit includes everything to install the unit (whip antenna, remote switch and indicator, buzzer, Coax cable, and wiring).
406 Mhz ELT Kit
406 Mhz ELT Kit
