Brief Description: Purchased 20W mini soldering iron
I purchased a 20W mini soldering iron to be used on very fine wiring. This tool was purchased specifically to solder headset wiring consisting of mostly 24/26 gauge wires. These wires are so tiny they require a low power and very small soldering iron.
I recently acquired a kit to convert my Peltor passive headset to active noise reduction (ANR). The conversion requires replacement of all the wiring in the headset (soldered splices on about 10 wires and six connections to ANR module circuit boards.
