Pete's RV-8 Web Site
Date:  6-28-2011
Number of Hours:  0.00
Brief Description:  Miscellaneous components received
I got some items this evening needed to complete some cockpit interior features. Image one below shows a Matco parking brake valve, some Grove brake reservoirs (mount directly on the pedal master cylinders), and a couple fuel gauges from Van's. Notice the T-handle cable I plan to use for applying and locking the brake (press the toe brakes, pull the cable, and twist 90" to the right to lock).
Image two shows a Safeair static/pitot installation kit. This kit includes static ports machined from aluminum that can be flush mounted to the fuselage using either flush rivets or tank sealant. It also includes quick disconnect fittings.
The final image shows the front and rear deluxe throttle quadrants from DJM manufacturing. These look much nicer than the standard kit components.
Brakes & Fuel
Brakes & Fuel
Safeair Static/Pitot Kit
DJM Deluxe Throttles
