Pete's RV-8 Web Site
Date:  9-9-2010
Number of Hours:  1.00
Manual Reference:  8-29
Brief Description:  More fitting of aft bottom skin
After further inspection, I decided to remove a little more material. At the aft end of the tube there is a weld line that insists on interfering with my skin so I ground and filed away a bit more aluminum. I think the fit looks pretty good but am not sure just how much clearance there should be between the tube and skin. There is sure to be some amount of flex and movement in this area even with all the components riveted and bolted up tight. May have my friend take a look and comment on this area as well.
From the Back
From the Back
From the Front
From the Front
