temp mounted and hooked up the data bus wires to intigrate the controls. Found that I needed to Install new software for all components to communicate so I went do Dynon and loaded the softweare from a USB.
Also found the pitch servo not communicating so a bit of Troubleshooting and i found the ground swapped with the AP disconnect.. Swapped and was able to to a test trim to make sure it functions.
