I continued labling wires with which plug and which pin each wire needs to go to. Then i was able to route them behind the panel to a general location for each plug. once the component is in place ill be able to make the connector.
I also made and mounted a Ground buss bar for all the Local Grounds instead of using a random screw or bolt and aircraft ground. 99.9% of this acft will have a dedicated ground with 100% connecton to the battery ground.
