Got the fuse flight level in the shop and worked on leveling the avionics shelf since the ADHRS must be flight level since there is no adjustment in the software.
The shelf took some time and trial by error using shims and spacers under the rail. Image 2 shows the spacers. Image 3 shows it up high on the right (Fwd) and Low on the left (Aft).
next up was re-arranging the ADHRS to face the right direction, then swapping locations of the ADSB and the SV Hub for better clearance under the pushrod. Now there is ample room.
Image 3 on the left of the pictre is a support rod that will hold the harnesses from the ADHRS and ADSB. I wanted NOTHING in the way of the rudder cables underneath.
Speaking of, I will be threading a 3/8 Nylon tube over the cables under the shelf so it does not have a change to rub on the shelf. it will be just like it is under the pilots seat.
