The aft avionics shelf is made and temp installed. the components are mounted so I can see where I need to run the wires and how i want the to lay out, I am planning on putting in a terminal board just for the Auto Pilot servos since they have a dedicated power supply and ground with the AP disconnect. from the Terminal board I will run a short SV Net Line to the SV Net Hub to connect the AP servo data lines.
The AP servo power and disconnect line is run from aft to fwd along with the ADSB quad twisted sheilded line. It is a serial line so it is not part of the SV net.
THe harness in the Rt MLG tower is growning so I had to put larger Adel Clamps in to accomodate.
