Finally got the flare tool in for the 37 degree fittings so I started experimenting on some short lenths. The First image shows the nice flare it makes so all is good to press on.
The second picture showes the lines on the bottom of the selector valve. the right tank line is in two sections for easy removal of the line if needed.
