Now that I have the Fuel pump and Filter on hand, I can layout where they will be installed. With the -8, the holes are already in the skins for the QB so set up was easy. The fittings that came from vans are the 37 degree aircraft fittings so I had to order a new fiar tool which is backordered so this will wait for a while.
The Fuel valve needed spacers per the plans to fit correctly on the bracket. the handle itself points to the tank selected.
