Now the prop is on, i can do the Ignition check to see if the Pickups behind the prop are working properly .
THey were not close enough and I could not reach the bolts to adjust them so, the prop had to come fwd enough to get the allen wrench in. I got them adjusted and used red thread locker and re-installed prop, I did not TQ or Safety the bolts just in case.
