Alternator fuse holders mounted and wired except for the Main Alt since I need one more terminal for it.
the Backup Voltage regulator is mounted and wired. It requires 12v from VPX along with the "ON" signal for Field to the regulator then to the Alt. Also needed a ground so I ran all of them and wired this one up. The main Alt regulator will be on the next order but provision have been made already for wiring and mounting.
Also created a diagram with wire numbers for the regulators. Lastly, Labled the wires.
