Finished design on the Throttle linkage, got bar stock to make it and got it welded to make sure it fits, next is to get the final bracket plasma cut so i can fabricate the final bracket.
created a TO-DO list with manny and did a section by section of the aircraft taking notes on what is left.
Started knocking out some of the small items... Safety wired the Flap motor rod end, riveted the upper ribs on aft fuse organized hardware for easy identification secured wire harnesses that were loose
