Matts Build Log
Date:  3-15-2018
Number of Hours:  4.50
Brief Description:  Fuel servo controls
Took the bolts and nuts off the sump so i can install the brackets supplied from Vans. Needed some modification to get it to fit just right. Once placed, I found that there was some interfearance with the fuel lines and the CHT wires. After the lines were moved, the control cable had the clearance to move freely. Im having some issues with the actual connection but that will be for next time.
