Main control unit that connects the Pilot and Co-pilot controls got the holes final drilled and all hardware located and temp installed.
The Elevator Control rod that goes inside this I ended up messing up the holes that mounts the Rod ends so I am awaiting those new Parts From Vans. Once that comes in and I get it fabbed, I will prime it and install the entire unit and work on the trim servo.
