Ran the 2 extra wires from the VPX and set them up in the software to run at 10 ams. Dug out the seat heat controls and harnesses. I then found a great place to mount them between the front and back seats under the floor. I put the controls in the space between the front and back seats on the right side. They are out of the way but easy access for both the pilot and co pilot.
The harness came pre wired with a relay for power, bulky but with a 10 am initial draw, it made more sence to use them instead of trying to rewire it completly. Although the vpx could handle it, it would require the extra input switches and more wire. I did it the simple way, as designed.
