3hrs Extended the EGT and CHT wires to meet with the EMS wires that were a bit short
4hrs the External Regulators isntall requred some more wires to be ran to the VPX and to grounds. I completed the runs and mounted the 1 regulator I have and drilled the holes for the Second one on order soon.
.5 Mounted the fuse holder for the Primary alternator. the backup alt fuse holder will be mounted next. then the main wires will feed them. I will order some copper buss bar to connect them to the AMP meter.
