Fitting the intake on the current Fuel servo has some challenges. the offset is about 1.5" off so I will have to cut and re glass the intake tube once I get it set in place.
I also made the filter support so that it can be easily removed and cleaned. Its more like a Nintendo Cartrage now. I do need to remake a bracket that supports it. It does not have the clearance on the rivets I need to be 100% secure.
I also had to cut a clearance hole near the servo (Pic 1) so the starter has a place to recess into. Once I have the filter done, I will glass it in place and make it whole again.
