worked ont he canopy rails that it rolls on and the mechanism that holds the aft securly.
Mounted the Frame rollers and then worked on the block that holds it securely when closed.
There was some fit and finsh work that needed to happen to make the rails fit the fuse and have the frame roll smothely without binding. The rails are a tight fit and need to be trimmed after set. Finally got them drilled and mounted.
then I worked the latching mechanism. Made sure it was assembled and that there is plenty of room for glass work when it latches. very smooth operation. Also drilled and tapped the external handle.
