Drilled out the remaining holes for the Gov Cable and started to route it. Found that I did not want to use the existing fire wall penitration kit so i had some Eyeball mounts ordered for the 3 cables. This will be much more secure and much safer.
Also put some Oil in the engine and did some safety wiring on unsecured nuts and bolts on the engine.
I got my new drill bits in today as well so I can drill out the undrilled hardware to safety wire as well.
