Back on the Prop GOV control bracket, The origianal mount design is supposed to go down and under the #1 cyl but there is no room since the intake will be there. the other option, one that others with the same issue have done is to go up and over. the bracket needs to be slightly modified to make is clear the cowling so i drilled new holes to make it fit more snug. Primed and Painted awaiting re-install
