more on my to do list is to get all of the components under the instrument panel ops and leak checked so i can install the top deck.
I needed to get fuel to the pump to pressure check all the lines to make sure they didnt leak
Went though each piece to make sure they were tight, installed a gas can and hose on the foor of the shop, Primmed the pump and let if flow though the hoses on the engine. Once purged, I capped the line to pressurize it and saw that I had 27 PSI with no leaks.
