Matts Build Log
RV-8
Ignition
The task of setting the pickups behind the fly wheel were a challenge becuae you cant reach them with the prop and flywheel inplace. had to partially remove the prop again to move it forward enough to loosen and set the ignition pickups.
I now have spark and RPM indication on the dynon!
RV-8 Home
1664
Brakes
cabin Heat
canopy
Comm
Cowling
Flaps
Floors
Gear
Lighting
Pitot/AOA
Rudder Pedals
Shop setup
Skin
Smoke
