Changed over the brass elbows that go from the master cylinders to the resivoir. the brass fittings were leaking. I will wait on the brake bleed until I swap the hard lines on the legs for the flex lines.
I forgot to install the fuse that goes from the output of the master relay to the VPX. Mounted it next to the battery out of the way and in a good spot for the cables. Awtg battery ends to finish
Re-design of the Ignition cooling cover. Now that I have found what G-10 Fiberglass is, I can cut it on the Laser cutter with precision. I am making the paper templates to get the dimensions perfect, then cut it out of the fiberglass, reinforce it and install the 3d printed duct I made.
