I had to Jack the Aircraft and pull the wheels off so I can get the unions attached to the Brakes. While I had them off, I packed the bearings.
Made the Brake line couplings and attached them, I used the Liquid sprayer method to bleed the brakes. I found that the coupling in the gear tower was not tight.. got down there and Tightened it up to find that the flair was bad.. had to remake the line. I then bled the brakes again and found that the master cylinder was leaking. The Brass fitting is not good so I ordered some different ones.
