Made up a ground cable to ground the engine to the stud that had the battery ground on the other side.
I also created the cut files for the Instrument panel so I can get it cut by a Laser cutter locally. Finish will be much better
I created the File to 3d Print my own Design for a Ignition Wire Gromet for the Firewall.
The ones on ACS are 20 bucks a piece... nope... Ill make my own. It will be the same part printed 2x so they overlap and rivet together to hold 4x RG 400 cables and 4x Ignition Cables for the bottom of the engine.
