mounted the ignition system on the engine side of the firewall
routed the wire harnesses back and forward
Desoldered the pickups so I can slide on a nylon tube for wire protection as they go under the cylinders, then re-solderd them.
completed assembly of the harness and installed them onto the ignition boxes
Utilized the last manifold ports the VANS provided in the kit for the Manifold pressure. one port for the manifold pressure sending unit, one goes to the manifold, and the last port (on the left) goes to the Ignition system.
