Went though many forums and did not find much of an answer when it comes to the cable brackets for this particular configuration. the one close enough was
He made the same modifications as this engine. the only difference is the size of the adapter to the sump.
This sump does not have provisions for mounting brackts so I had to get creative on lcoation and angle. This final design was the 3rd for the day and It will work just fine. I will take the file and get it cut on a CNC plasma and finish the install once I get the gaskets.
